rhagfo
Oct 26, 2019Explorer III
ScottG wrote:rhagfo wrote:ScottG wrote:
I would not want any truck/fiver combo that gets within 80% of the trucks GVWR. Only because you may end up hitting the bump stops on a regular basis and that doesn't make for a very nice ride and can be really hard on the hardware.
I would love to know the person that started the 80% rule!
I carried a 32’ 12,500# 5er with our 2001 Ram 2500, I was 1,700# OVER GVWR and just under rear GAWR, don’t ever recall hitting the bump stops, heck hardly got to the overload springs!
My post has nothing to do with the 80% "rule" (which I have NEVER promoted). And that rule was generally about not pulling more than 80% of your trucks rating.
You were also using a HD truck. A half ton is more likely to hit bump stops because the suspension is setup for a better ride.
For anyone to actually suggest someone exceed their GVWR is bad advice.
Well I never suggested that others exceed their GVWR, just a situation I was in and that in my particular case I didn't have an issue, and that one should be able to carry full GVWR as long as it doesn't exceed either GAWR.
I will point out that the TV in question had;
Front axle rating of 5,200#
Rear axle rating of 6,084#
Total axle was 11,284#
TV GVWR was 8,800#
Now days 1/2 tons have GVWR that are so close to the total axle ratings, that you can be within GVWR and exceed rear axle rating.
I didn't like being that far over GVWR, even though the package towed, handled, and stopped just fine.
I solved my issue with a 2016 Ram 3500 DRW, now I have 1,300# of spare capacity.
About Fifth Wheel Group
