jake122288
Oct 03, 2013Explorer
questions for full timing in my new 5th wheel...
Well as the subject suggests im going to be "full timing" in my 5th wheel. Its nothing fancy. its a 2001 fleetwood mallard 275b. It is currently parked inside of a enclosed pole barn and this is where it will stay. (some but poor insulation and no heating for the building with full electrical hook up)
I just have a questions for full timing it. My first question is about the lp system. I currently have 2 30# lp tanks. I would like to switch that to a pair or 100# tanks. I keep finding posts in regards to a "extend-a-stay" but everything i see is for motor homes with "mounted lp tanks"
I do want to change my regulator to a auto switching one as well. Can i just change my regulator and then replace the hoses that go from the tanks to regulator with longer ones that can reach my 100# tanks? Would these hoses have to be hi or low pressure hoses?
Is there anything to do special in regards to changing the regulator? What should the pressure be for the regulator?
My next question is in regards to venting the furnace.
The building its in is a 32' x 16' with 16' ceiling (20' at the peak) The building has 4 roof vents. Do i need to be concerned about venting the furnace outside the building or with that space will it be safe to just leave as it is?
And my final questions are regarding fresh water. Beings the 5th wheel is inside how much do i have to worry about my tanks and line freezing? I will be putting up skirting shortly as well. is there anything i can do to further prevent my lines/tanks from freezing. Water isnt a huge concern as we can use the house as well for laundry, dishes, showers and such.
Sorry this is so long and probably hard to follow. Im just losing my mind trying to get everything done as winter will be approaching fast.
Any other tips are greatly appreciated. =)
