drillagent's avatar
drillagent
Quick Brake Fix
I need to fix broken brake springs on both drums on one side of my 5er. I don't have time to get the trailer to the Auto Craft shop so I'm going to have to do it in the storage lot. My question is, can I remove the drum, fix the brake, and replace the drum without having to replace the grease seal? Thanks for your input.
  • I would be worried about more damage done by the broken springs--scored drums and shoes. You might not be able to get by with just the springs.
  • Yes you can do all that without replacing the seal. Done it many times.
  • Me Again wrote:
    How do you know you have broken springs? No clicking when turning the star wheels???? Does the trailer have a history of breaking springs?
    Chris
    A couple months ago I crawled under the trailer to find out what kind of axles I have. While under there, I noticed wires hanging out of the brakes on both the curb side brakes. Upon further inspection, I realized they were broken springs. How or why, I have no idea. I bought the trailer used, so I don't know if it has a history of breaking springs. Honestly, I don't even know how long they've been broken. I do know that I've had the brake controller maxed out since I bought it.
    Chris
  • If the seal is OK now, there is about a 90% chance that it will be fine. Just be careful pulling the drum off and don't mess around with the inner bearing. I pull the drums off regularly and rarely have an issue with a seal.
    Brian
