Jmauseth's avatar
Jmauseth
Rain, Leak, Dicor but... what happening in walls?
This past weekend I had a leak, after a full week of Seattle rain, took the trailer out and found a fair amount of saturation to the carpet in our front living space of our 5th wheel. Once the rain stopped for a second I got up on roof and noticed a hole in the dicor between the vinyl roof and the front fiberglass cap seam. I covered it with a garbage bag. Morning arrived and I was able to clean the hole, dry it the best I could. Next day I used wifes hair dryer and also some rubbing alcohol to clean it. Heated up a tube of dicor and applied full length of the seam. I used fans, shop vac, space heater and as many towels as i could find to dry up inside. Pretty dry that I could see not in the walls. since this is front living, there is a tremendous amount of cabinetry surronding our fireplace, tv and stereo system. No way i could see to get to the walls behind.
Question for everyone - its still wet/humid here and I dont have storage with power. I am not too concerned about the carpet but what might be going on in the walls that I need to be concerned about? i do not have any ability to get it to dry humid spot for another few months. anyones thoughts would be appreciated. My father is a seasoned RV'er and mentioned the type of wall insulation is the key. I have a Keystone Cougar and am not aware of which type.
Thank you - John M Seattle, Washington
❚ Did you read the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
