laknox
Mar 26, 2015Nomad
pyoung47 wrote:
I'm not sure there is a good way. I believe there is a caveat against jacking on the axle tube since it may collapse. Jacking on the frame is sometimes tough if you are not on concrete. I roll one wheel onto three 2 x 8's. The patented device appears a bit precarious to me. I always hook to the truck for stability.
Not collapsing the tube, but bending it if you jack too close to the center, which some not-so-common-sense-types have done. To me, if the spring perch is strong enough to support the springs, it's strong enough to support the jack.
Lyle
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 22, 2026
