SoCalDesertRid1
Jul 13, 2016Explorer II
If the springs are not already on top of the axles, you can do a spring over axle conversion, which gains about 6" to 9" of height, depending on your axle tube diameter, spring pad height and spring pack thickness.
Another thing you can do is build a subframe from square or rectangular tube, which welds between the trailer frame and the spring hangers. Height gained is equal to the diameter of the tube.
Yet another way to solve the problem is to eliminate the pickup bed and replace it with a flatbed or hauler style bed.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
