tinner12002
Jul 17, 2016Explorer
If you already have spring over, springs on top of your axles, then you can use spacer blocks under your leaf springs to raise your RV. I have 2" blocks under my springs on both my tow haulers with no issues. I also upgraded my u-bolts too when I did that by using heavier, thicker u-bolts. If you use the blocks from Trailer Block company, just purchase their blocks only and source your u-bolts and tie plates elsewhere.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
