honda_man's avatar
honda_man
Raising Fifth wheel
I want to raise my trailer a few inch's my leaf springs are already on top of the axle is blocks the answer to get it higher, already lowered the hitch to max bed to trailer height.
  • phillyg wrote:
    You need what's commonly referred to as a sub-frame, which is just pieces of square hollow stock about 6-8' long welded to the bottom of the frame, to which the spring shackles are attached. The rise is determined by the thickness of the square stock.
    That's how I did a 4 inch lift.
  • You need what's commonly referred to as a sub-frame, which is just pieces of square hollow stock about 6-8' long welded to the bottom of the frame, to which the spring shackles are attached. The rise is determined by the thickness of the square stock.
