goducks10
Feb 26, 2021Explorer
Slownsy wrote:
I think you are reading it wrong, front still lower than rear, but if rear sags 2” then head lights points op higher and blinds oncoming drivers.
I get what you're saying. I'm on my 3rd Ram and have never had that issue happen when hitched up, whether with a TT or a 5er.
I wonder if your headlights are set right to begin with?
Not trying to be condescending or anything like that. I'm just replying based on my real world experience after owning two 2500's and never had a headlight issue.
I towed my 5er for 6 years and towed a TT with a 1350 lb TW and that did raise the front up a 1/2 " or so after hitching up. Rear dropped 1.5 or so. Still didn't have a headlight issue.
I realize you have 200 lbs more for pin but like you mentioned your rear sags about the same as my 1800 lbs did.
Every truck owner that tows or hauls anything heavy has the rear end drop. Some less than 2" some a little more than 2". Never read much about headlights too high in those circumstances. A 2" drop should be well within OEM headlight angles as to not bother on coming traffic.
Assuming you trucks all stock I think I'd get the headlights checked out.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
