Was wondering what, besides the suspension, is the difference between a Ram 3500 and 2500 i.e.; brakes, axles and are bearing loads in both trucks the same? Do both have the same frame?
Here is the 2021 Ram Towing Chart that gives you the capacities of different models. In addition to diesel or gas, ratings vary based on trim level, box length and cab configuration. Figure out what your pin weight and cargo needs are, then buy the truck that will do the job.
