GregK
Nov 12, 2013Explorer
Ventureman wrote:
NO! If the gasser is rated at that RPM then it's not "working harder" than a diesel turning at its rated RPM. As to fuel consumed, the diesel engine isis more efficient at doing work.
The part you may be missing though is the diesel makes its power in the cruising RPM range while the gasser makes its power well above the cruising RPM range.
Therefore the gasser is working harder because it isn't within its power band RPM range.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
