rhagfo wrote:
NC Hauler, while the GVWR needs to be taken in to account, so does the dry weight and carrying capacity.
There are some lighter 5th wheels that have huge carrying capacity and a 10,000# to 12,000# GVWR and under 8,000# dry weight or less. So in reality both weights need to taken into consideration.
Then there is the subject of GVWR of the TV, and this is where personal choice comes into play. Most realize the GVWR of 250/2500 is based on tax and registration laws, not the capability of the TV. Ford offers a F350 with GVWR of 10,000 do you really think that is all it can carry?
I understand all that, and I understand some can carry more than others and that most probably won't load to GVW...BUT it is really silly to look at a 5er, or any other camper for that matter, LOOK AT EMPTY WEIGHT ONLY, And "empty or dry pin weight" and USE THOSE numbers to purchase a TV to tow with..It's not realistic
I stated the 2500 could tow the 5er..I merely suggested that OP use the GVW to get a better idea of his pin weight...The 5er he's talking about is EASILY towed by a 3/4 ton truck..Heck I towed a 5er with a GVW of 14K and towed it with an 03' Chevy 2500 D/A...no big deal
I'm not going to get into all the supposed or real reasons "why" a truck has the GVWR it has, believe it or not, I understand all that.. BUT, being an Engineer and in manufacturing for the last 41 years, I'm a spec man....I go by manufacturers recommendations...can't help it, it's what I do..Thus the reason I'm so vehemently called "The weight police"...I try to stay under GVWR and GCWR, and then, I don't have to really worry about if I'm over loading axles or tires...It's so much simpler for me:B
No one has to do it the way I do, why should they, I just gave an opinion that his truck could tow the weight he asked bout..I stated GVW of the 5er because I've seen A LOT of people on these and other forums using "dry or empty" weights to figure what TV they need...again, "not real world".
