NC_Hauler
Jul 21, 2014Explorer
BusaGuy wrote:
The only thing that I do not like about the new trucks is that stupid fuel additive. Heck we are already spending almost $4 a gallon, then add this extra additive to it and it is almost $4.25. Don't sound like much but geez this is getting crazy.
?? How often do you think you have to add DEF??? I buy DEF at the pump for $2.55 a gal....I get anywhere from as low as 800 mpg of DEF to as high as 1300+ mpg....a very, very small amount . So at 5.5 gal tank holder, which the most I've ever put in it at anyone time has been a little over 2 3/4 gallon, again, at $2.55 a gal...I can get 5,000 miles with 5 gallon's..oh, and I the bonus is I get better mpg using DEF, I can compare this to identical 2010 and 2012 Dodge/Ram dually's.
To the OP. I have the picture frame adapter with a Reese 20K Signature 5er hitch and have no movement in the hitch.
If you have it locked into place on the adapter, I don't see and issue, unless it's moving a 1/4" or some really odd amount. My adapter also came with 4 bolts to use to lock down the hitch if one didn't want to use the locking pins...or was towing a much heavier 5er.
About Fifth Wheel Group
