Grit_dog's avatar
Grit_dog
Navigator
May 05, 2021
Ramp door patio DIY. Whose done it?
So although I basically don’t even have time to replace the batteries and get everything up to snuff on the new camper, already thinking about making the back into a patio on our new to us Torque XLT T29
Sounded cheesy to me at first, but we mostly do summer camping and it has the rear screen wall, so leaving the ramp door open when ya can will be awesome!
Appears the ramp is rated for it as its advertised with that model, ours just doesn’t have the option on it.
Not interested in the $1000+ fence and stair setup. Just the cables and a step stool for access.
Anyone made their own?
I’ve found a couple “kits” all inclusive with the fencing and all and they’re $$$. One place makes a cable kit for like $175.
But looking at it, for under $50 in parts, it seems pretty easy to do with a trip to the hardware store and Amazon. Might even do epoxy swaged ends.
Anyone roll their own here and experience with it?
Adjustability? I can see adding a turnbuckle to each cable could be good, but assuming I just use Crosby clips and don’t swage the ends, I can make them the exact same length and still adjust if for some reason one cable is taking more load.
  • ^Thanks.
    Thought about that but would have required some fall back stands, more stuff to lug along and a fair amount of adjustability for sloped sites.
    I just installed a D ring tie down on each side of the ramp door and cut a chain to length for each side. Super simple and quick.
  • If you want it quick and simple, just use a couple of ratchet straps and prop the tailgate into a patio. Didn't cost you a cent. No modifications, just hook them up.
    A fellow camper purchased a toy hauler similar to mine. His had a dedicated convertible tailgate with railing and some type of cable system. Total PITB to get all that gingerbread out of the way to get his bike in and out.
    For me, just hook up a couple of ratchet straps and sit out the lawn chairs. Just don't drink too much and fall off because there is no railing.
    OTOH, I've only used my ramp for that once. I usually get my outdoor rug, set up my table and grill, the lawn chairs, turn on the stereo, good to go. And I don't worry about falling off my ramp.
