Jbar88's avatar
Jbar88
Ramps for Gen. in side compartment
Hello everyone. Need some help I need to know if there is a light weight ramp that I can use to roll my Gen i the side compartment of my RV. I had back surgery last June and I cant pick it up any more. Any Idea's Thanks Jbar88
  • I have seen slide out trays made for pickup beds. Maybe one of these could be bolted in the 5th wheel storage area. Then you could simply slide it in and out as needed.
  • Check harborfreight.com and search "ramps". Should be able to find some there.
  • Yep there should be a way to set up a winch or hoist that would slide in/out of center compartment to assist those of us with bad backs. I have seen similar things in the front compartment of 5th wheels.
  • I use the bolt on ends you attach to dimensional lumber available at big box stores.
    They double as leveling blocks for the tandem axle.
    Good Luck, Mike
