kaiserrw
Aug 15, 2014Explorer
"It's really amazing how people will stop just short of having what they want/need! And it's usually mot much more$$$."
Amen! About a month ago, I took out the 30amp circuit I used for my old trailer and put in 50amp circuit because I want the ability to run A/C, water heater, refrig, etc. when it is here. The main expense was the 65-ft of 6/4 wire at $3.27/ft. A double throw 50amp breaker, one 50 amp RV Service box from Lowes (has the plug and is pre-wired), a 6-ft piece of PVC(elec), and a couple PVC fittings is all that was required. (Plus the know how) $320.xx and everything in the RV works.
Like someone else said, if you must hire an electrician; then acquire the materials, partially do the work and have the electrician make the final hookup. Don't forget to get your permits if that is required where you are.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 20, 2026
