rtaylor0830ExplorerMar 06, 20166pt hydraulic leveling systemCan you use the leveling system to raise tires off found for service ( bearing repacking etc).
chrizgExplorerSep 09, 2016I was told that if you lift all 4 tires off the ground the axles would flip. Is that true ?
Related ContentThinking of removing Hydraulic levelers.Bigfoot hydraulic levelingHydraulic Leveler Removal6 point hydraulic leveling - worth it?Bigfoot hydraulic leveler install
