Acdii
Jul 11, 2020Explorer
philh wrote:
Stupid question, can I buy a 50a unit and use it with a 30a trailer? Longer term plans have us upgrading to larger 5th wheel
If pedestal type that plugs between the pedestal and RV cord, double check with the manufacturer, but it should if plugged into a 50Amp socket. If the permanent installed type, it might not. Pretty sure it needs to see both legs in order to activate.
I just bought and brought home an Arctic Wolf 3660SUITE. It is 50 AMP, runs fine on 30 amp and surprisingly enough both AC's will run at the same time, they must have soft start kits already installed, the second one started up without issues and the running one didn't even give a grunt when it did. Of course that was just a test and I am running on just one AC.
However, my plan was to install a fixed 50 Amp Surge/line condition unit, but after looking where the line comes in, it is sealed up, so not going to touch it, so looking for the pedestal mount one instead. Suggestions?
About Fifth Wheel Group
19,013 PostsLatest Activity: May 18, 2025
