Jackathan
Oct 13, 2021Explorer
I have the steel Andersen. The instructions that came with the hitch stated to re-torque the top bolt after placing the full tongue weight on the ball. So, after lowering the rv onto the ball, I loosen the two locking bolts, and re-torque the center bolt, then re-torque the locking bolts. Makes a big difference in the towing experience. I only do this once, when installing the hitch. Then, for subsequent hitching and towing, I don't adjust it. If I remove and re-install the hitch, I perform the procedure again. Andersen address this in the FAQ here: https://help.andersenhitches.com/faq/what-should-be-the-torque-of-the-top-bolt-on-the-ultimate-fifth-wheel-connection-hitch
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
