ronschamingjr
Sep 01, 2013Explorer
bad99ram wrote:GoPackGo wrote:
One more question to the person who had his fuel jell up.
In areas with cold weather (well below freezing in winter) - Sometimes a station (especially an in-town station that caters mostly to non-semi vehicles) will keep selling straight #2 longer then they should as winter approaches. Straight #2 will start to jell at about 20 degrees if I remember. At some point the station starts treating it with chemicals to lower the jell point as they get further into the winter season. The other way to improve the jell point of #2 is to add #1. My Father-in-law was a trucker and told me that cutting with #1 is the best way to prevent jelling problems. And based on my experiences with jelled fuel, I would agree. He also said that stations keep adjusting the mix as they get further into winter. I'm guessing that up in the really cold latitudes they run straight #1 in Jan/Feb.
When I lived up north I used to treat my fuel but I was never real confidant that it would work at below zero temps. I always tried to buy fuel from a station that mixed in some #1.
The disadvantage to #1 is that it does not lubricate as well as #2.
So I wonder if somehow you could have got caught up in a situation where it got cold and the fuel wasn't treated for the temps. And then you finally got a load of treated fuel which solved the problem.
Tim
Just for that reason when I put my tow truck in storage in October, I run it down 1/2 tank and fill up with No #1. When I take it out of storage at the end of December I don't have to worry about the fuel gel problem before I head south. Sometimes here we have -30 by that time. Stations have the winter mix set up by then. I do use power service but will switch to the winter stuff until I get far enough south.
It's been several years since I had the jelling situation. No problems since dropping and cleaning the fuel tank the second time. Also used some Bio-Kleen in a few tanks at that time and discontinued the cetane additive. Never could find a mechanic--even the dealer--who could say for sure what was causing it, but whatever it was, it was a major pain in the you-know-what.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 03, 2021
