dannko wrote:
Ctimrun wrote:
holdinsteady wrote:
At this point I am not expecting to need WD or sway control.....hoping the torsion axels on the trailer will take care of sway issues.
I've talked to a couple owners who are pulling ATC trailers with 1 ton trucks without WD/sway control and have had no issues. Eager to hear your results. Thanks again for the info.
Do you think a standard 6.75 bed 2017 F250 Super Duty SRW would also not need the sway distribution setup?
I wouldn't think it would make much difference between an F250 or an F350 as long as they are both SRW trucks, only subtle differences between the two. Long bed vs short bed might make a bit of a difference. The weights on these ATC trailers shouldn't overload any (fairly recent) 3/4 or 1 ton truck.
Edit: looks like HVAC is towing his 28' with a half ton Ram. Any issues at all hvac? How does your truck do with your trailer? Have any pictures with the truck and trailer connected?
