heavyodie1
May 25, 2015Explorer
Old-Biscuit wrote:
You have a 10 gallon DSI propane water heater
It has 2 t-stats
Brown wire goes to normal t-stat (preset 140*F)
Red wire goes to ECO (high temp) t-stat (preset 180*F)
T&P Relief valve OPENS at 210*F/150 PSI
Weeping ......
Water swells when heated. If air pocket in top of tank (there by design) gets lost pressure can build up causing T&P to weep
Turn off water supply
Open faucet hot side to relieve pressure
Open T&P via lever....let snap close when water stops running out
Close faucet
Turn on water supply
Thanks. I've done all of that with no improvement. The water is steaming hot when the pressure relief starts weeping so I don't think there is a problem with that. Don't know what to try next.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
