JohnD222
Mar 08, 2014Explorer
Life is good if that is all that you found. When it finally is warm, be sure to get on the roof again to see if any of the dicor sealant pulled away from the roof penetrations.
Re the plastic trim, it was probably dropped during install with a hairline crack you did not or could not see. That area around that small crack did not shrink uniformly and it enlarged slowly with each freeze/thaw cycle.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
