MoparBob
May 24, 2019Explorer
GHop wrote:RollandB wrote:GHop wrote:
I think I ordered the wrong one. Where did you guys take your measurements from? I went by an Rv web site which said to measure from center wheel hug to center wheel hug which measured on my rig 35inches so I purchased the SRE2 735x. After going on MorRyde I found they wanted you to measure from one hanger to the second hanger so for my rig it was 59inches.
Hub to hub centers should work, or the centers of the axles would do the same. Should be either 33 or 35”. I’ve seen the MorRyde site with the page of measuring the hangers. I found that isn’t truly accurate as Northwood who makes our fifth wheel has different axle spacing but I have 35” axle centers.
If you are measuring I would also compare the three holes in the CRE3000. On the one I had for a 35” centers caused the axles to be nearly 33” as the dimensions of the three holes was different than the OEM equalizers. In Talking to MorRyde they were stumped on the issue the CRE3000 caused (which isn’t a problem on the SRE4000.
Thank you for responding. I measured the Dexter equalizer and you have six inches and the two center of the mounting holes on the SRE 4000 is 8 inches. After measuring all of this I called MorRyde and was told I should have ordered the SRE 733.
I just measured 34.5" between hub centers on mine, but there is just a little bit over 6" in between the shackle mounting holes on the CRE3000 that is currently installed...looks like I need to call MORryde.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 15, 2026
