MLATION
May 06, 2015Explorer
spud1957 wrote:MLATION wrote:
The difference between a 250 and 350 is NOT springs, spacers, sway bar, etc... The rear axle in the 350 is larger than in the 250, hence rated for more. Same casing but different axle shafts.
Ford Truck body builder
Go to the link above and click on "2011 F-Series Super Duty Pickup F-250/350/450" Open the PDF and go to page 73 Rear axle specs.
NO NO NO! That misprint has been discussed at least a zillion times. The larger axle you are referring to is in the wrong column.
Proven by Ford Engineers. Proven by part number BC3Z234D. Same axle since 2011 to current MY.
THE AXLES ARE THE SAME!
Here is the Ford order guide for the axle. Scroll down on the left. You will see the part is "also fits F350".
F250/350 axle shaft
seriously?? for 10 YEARS Ford has misprinted specifications for 3rd party body builders.. I don''t think so. Think what you want.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
