You are going to get a lot of responses with a wide range of prices and quality. I have lived in a Teton, Bounder (Class A) and Open Range and each has it's advantage and disadvantages at the same time I've known other full-timers with expensive RVs that seem to have the same problems I have. True construction is everything but all trailers are designed for over the road use. If you are planning alot of off-roading or rough roads then consider a "heavy" fiver otherwise go out and get what fits you the best i.e. storage, kitchen, bath etc. at the price you can afford and enjoy full-timing!
