vankids
Oct 29, 2016Explorer
To OP, if you are looking at a used Ram 3500 make sure you do your diligence on the 2011. Factory supplied trailer brake controller is not useful for anything over 4000 lbs. I bought the truck new and bought my fiver 6 months later. First two years of pulling(just short trips with limited hill) I was blaming fiver. Had trailer brakes adjusted, changed controller settings and still not stopping power unless you applied manually. Brought it to dealer to check out controller, they said all was fine.
This past summer had to make panic stop at 50 mph and fortunate that I was quick with manual otherwise I would have been on top of cars in front.
Did a google search. 2011 Rams with factory supplied controller are only good for light towing. Subsequent years have three settings(light, medium and heavy) which you can select thru your EVIC. Brought truck to dealer, they did not believe me but one day later they acknowledged that only has one setting and they can't flash an update. Solution is an aftermarket. Great, I bought a truck capable of towing 15,000 lbs but don't try and stop it. Other than that great truck, great exhaust brake and average fuel economy
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
