windellmc
May 06, 2018Explorer
IBcarguy wrote:
I have a new Jayco Eagle HT and it had the same problem. The tanks don't fit far enough into the opening so the door clears. I fixed mine by removing the tanks, and I used a grinder/cut off wheel to remove some of the frame lip where the tank sits at the bottom, allowing the tank to sit deeper into the opening. I also used a turn buckle at the top of the tank mounting bracket to pull the tops of the tanks deeper into the opening because it's a flimsy piece of metal that the tanks sit on and it would let them tilt outward and interfere with the door. I just snug the turn buckle and it pulls the tanks more upright creating clearance for the door. I can send pics if you want to see how I did this.
What was your build date? The ones I saw were early 2018 builds.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
