Macman83
Apr 20, 2015Explorer
Our 2013 Voltage is 42ft. Long and weighs in at 16K empty on the CAT scales. The main difference from the double to triple axle is you drag a tire when you turn. Our pin weight is 3450lbs, you can compare it to yours, but your truck should handle that as well. Ours has the 14ft garage, and the teenagers love it back there. I really don't think you will notice much difference.
Good luck, hope this helps.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
