jdiffend
Aug 20, 2015Explorer
I picked up a used 2005 Cedar Creek Daydreamer a couple years ago and whoever had it never took it back to the dealer to have issues fixed under warranty.
The entertainment slide was so poorly aligned that there was a gap on the right side and I know it came from the factory that way. When I had it fixed the service person had to trim a cabinet knob to shorten it enough so the slide could be moved over enough to seal.
I've found other issues that were clearly from the factory so I can't say I'm thrilled with the construction.
One issue I'm not sure about is who installed a 2nd converter charger instead of an inverter to run the residential fridge. I don't know if it was the factory or the dealer but the breaker box definitely had someone label it as an inverter.
About Fifth Wheel Group
19,027 PostsLatest Activity: Jun 19, 2019
