TrickyRicky
Nov 27, 2015Explorer
Sometimes it can be the cables and sometimes the valves themselves. Fixing the problem will probably mean exposing the valves and the cables by dropping some of the belly wrap. Look for sharp turns in the cables that is one of the biggest causes of hard to operate valves. The cables can be usually rerouted to form a straighter line sometimes it means cutting the cable to remove some of the slack that is coiled up. When the valves are exposed disconnect the cable and try pulling the cable is it still hard then it is probably the cable causing the problem. Most valves have 4 bolts with nuts holding the two halves together and they are too tight squeezing the inside rubber seals to put excess pressure on the sliding gate. Try manually moving the valve may need a pair of pliers or vice grips on the shaft that the cable was fastened too. If the valve moves real hard try backing the nuts off just slightly and try again. If you have loosened the nuts and the valve now works OK you should put some water in the tank to make sure the valve does not leak before closing the belly wrap back up.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 03, 2021
