dsrace
Apr 13, 2023Explorer
Hoping to run to the cat scale this weekend to weigh the truck and trailer loaded for a camping trip. Might run back and load the rail and weigh it loaded as well.
Been re working dune sport custom winch install since mon evening. They used 4- 1/4" lag screws to screw a 12" long 2x6 to the floor and another 4 to screw the winch to the 2x6. Obviously the back 2 will pull trying to wind up 2000 lbs. 8' long rope gate and a 36" climb. Not the worst but lag screws into osb/ply wood doesn't cut it imo.
Made some plates that bolt the winch to the floor and the steel left to 4ight cross frame underneath. Best I could do and waaaaay better then lag screws. The front lag screws began to pull out. Got really lucky the winch went into thermal over load and shut down before the winch blew off the floor and shot at us, letting the buggy run down the ramp gate.
They used a 3500 lb badlands winch from harbor freight. Nothing wrong with that brand imo, i have never had issues with them before. At 2k lb and half spool, badlands states on the box that the winch has a 130 amp draw. My 200 ah agm battery is 14' from the winch. 28' round trip as this is dc power and dune sport used 8g wire. Between the terminals not being even finger tight and to light of wire, prob why the winch shut down.
Spent the last few days re inforcing the attachment and stepped up to a 4500 lb winch that only has an 80 amp draw at 2k lbs and half spool. Going to install a 50 ah lithium next to the winch with its own charger. Plenty of room and I'm only pulling it up an 8' long ramp gate and 14' into the camper..... 4 times a year. So much for the $550 winch option.
badlands 3500 lb winch draw
About Fifth Wheel Group
19,012 PostsLatest Activity: Sep 16, 2020
