hilke40
Oct 13, 2020Explorer
If you have the single handle to by pass , that is probably not your problem. When they went to the single handle bypass method, they put a one way check valve on the top line of water heater. It is letting water back into heater, which it should not be doing. They are around ten bucks and just screw off, after you remove the water line.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
