Tireman9
Feb 28, 2015Explorer
BFL13 wrote:
If STs are to be kept at full pressure even when the weight doesn't require it, but LTs' pressure is adjusted for the weight, then it is more likely the LT would not be at full pressure. So that would be fine for the weight but not so good for the sheering?
Should the advice to be at full pressure despite the weight also go to LTs when mounted on trailers to help with the sheering?
comments and advice deleted by author. good luck and safe travels.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
