riltri
Jun 27, 2022Explorer
JRscooby wrote:
I can't see the issue. A 2 lane road will likely be 25 foot wide. King pin to where tandem pivots likely well under 30ft.
Crowd hard to right until your past drive, crank hard left aiming the left side of truck for right side of bridge. This puts trailer axle as close to in line with driveway as can. Stop just before steer axle leaves pavement. Cut hard passenger, back up enough that hard cut to driver will let you get TV as far right as culvert will allow.Stop just before steer axle leaves pavement. Cut hard passenger, back up enough that hard cut to driver will let you get TV as far right as culvert will allow. Once the rear axle is across, cut to passenger if needed, then back to driver to get TV back on drive before trailer gets off.
Ain't no step.
I've been running that thru my mind. If I initially go just past the drive 2-3' so I over-shoot the drive. Turn hard left and pull up to the edge of road, then turn steering to passenger side and back up. That will allow my front tires to make it on the second try and it might get the RV axles far enough right to make it.and it might get the RV axles far enough right to make it.
About Fifth Wheel Group
19,013 PostsLatest Activity: May 19, 2025
