igor2brvn
Nov 25, 2014Explorer
4huskers wrote:
If putting the truck in neutral doesn't do it try putting it in drive and then in reverse. Then apply the emergency brake. You want to get tension off the hitch. Is the truck lined up pretty straight with the trailer? Too much do an angle can does problems too.
X2. I have DW put truck in drive then reverse while I pull the release lever. Almost every unhitch requires this maneuver.
About Fifth Wheel Group
19,035 PostsLatest Activity: Feb 16, 2018
