jonrjen
Jul 15, 2017Explorer
Why did you replace the break away switch with a replacement? Was there an issue with the original? Did you check the voltage reading on it before replacing it?
Did you wire the new switch directly into the junction box and tie it into the wire harness or cut the old wire leads and tap into the old wire harness of the original break away switch?
Have you check for a voltage reading at the wires in the junction box located at the hitch?
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 20, 2026
