beazleybub
Feb 12, 2017Explorer
I'm sorry but, you are mistaken. My rig is stick built, 2" studs, 16" on center.
With that said, I have decided to break the mold and use an alternative method to re-side my rig. I know weight is an issue, so after much research, I have decided to use "LP SmartSide 38" panels. These panels do not require a backer and can be nailed or screwed directly to the studs themselves. The (0.315-in x 48.563-in x 95.875-in) panels only weigh 41 pounds each, which makes them lighter than the plywood they will be replacing. The panels are not expensive, at $26 each I can completely re-side my entire unit for under $600. The only issue installing them will be with the nose of the trailer. The panels cannot be bent, so I will have to either use a different siding for the nose radius, or reconstruct the nose to a flat profile.
About Fifth Wheel Group
19,012 PostsLatest Activity: Sep 16, 2020
