alarmin
Aug 02, 2015Explorer
WW fresh tanks
My WW has (2) 50 gal fresh tanks. They are ABS and joined by 1 1/2 (?) hard pipe. I have a leak caused by the 2 tanks being joined by the hard pipe that I fixed with Plasti-mend. The flexing between t...
arhayes wrote:Pex should work but I would like to try and find a way to connect the larger pipe first. This way when I fill the fresh tank I won't have to wait for the 2 tanks to level out. If I did go with Pex, any suggestions on what fittings to use so it would be sturdy / reliable
Would Pex tubing not work? Not sure about reducers, etc as it typically is not that large.
