dedmiston wrote:
pcassidy111 wrote:
I talked to WW a couple of days ago about my 05 FS 2600 and they said it was not included in the recall for the prophylatic fix, only the 01 and 02's.
Not true. My '05 FS2600 was covered.
Have you had the prophylactic fix done to your trailer yet? If so what did they do. Who did you talk to at WW and did you give them your vin number? It is my understanding that it is only the trailers that have their tongue formed by the bending together of the 2 pieces of C channel that run the length of the trailer are in need of the fix. According to the diagram of the fix 2 pieces of C channel are welded in between the point of the bend for the tongue and the front of the trailer and the joint is reinforced with a gusset. On my trailer (date of manufacture 04/04) I have 2 pieces of 6 inch C channel that run from the front to the back of the trailer. The tongue is formed with 2 separate pieces of 6 inch C channel. The geometry of my frame is identical to what the fix accomplishes, less the gussets. Are trailers with my frame geometry getting the gussets welding on to them? I gave WW my vin number and they told me it was not elegible for the fix.
