justme
Dec 22, 2017Explorer
Cummins12V98 wrote:justme wrote:
Last summer I got 12.1mpg average from San Francisco to Connecticut on my 2012 F350 diesel pulling a 40ft trailer. I set my cruise control to 62mph most of the time. I got 12.2 mpg from Connecticut to Florida recently. I use ctane additive/booster all the time and never use B20.....
Using display or hand calc? What is your combined weight and is your RV a wide body? Most people never use B20 since the tag says "up to B20".
I'm using the display after I determined that it is accurate and my combined wieght is 24260 according to the CAT scale. Also it is not a wide body. Ford says B20 is OK and does not say up to B20. However they recommend ether 5-40 synthetic or 15-40 non synthetic with B20 which is the same recommendation for severe duty. B20 burns hotter and does not have the BTU content that diesel #2 has which means translates to lower efficiency and less MPG. Also B20 is harder on the high pressure fuel pumps and injectors on the newer trucks.
About Fifth Wheel Group
