Durb
Jul 02, 2017Explorer
If you have one switch and they should both go down together then the individual jacks are probably ganged together by a tube or a rod and rely on a single motor. There could be a pin or bolt that connects them together that is either missing or sheared. If a tandem system like that is not blocked correctly so that the stabilizer pads hit at the same time then it will put undue stress on the components.
I'm guessing this is not a new trailer but a new problem. If it is a new trailer and the stabilizers are not ganged then you might have a separate switch somewhere else. Time to get on your back and check it out. Not a fan of ganged stabilizers. My son had them on a TT and they were a pain.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
