I have an 09 1500 6l max tow. I will be able to tow my new 5er and stay within the specs, but it will be close.I am worried about rear end sag, what is a good way to relevel my truck if required.Airb...
I would prefer Timbrens. Because when you are not loaded, the Timbrens do not increase the stiffness of your suspension. They only work when under a severe load...when you need them. Makes for a smoother ride when not loaded. And you don't need to mess with airing them up or down, as needed for the situation. JMHO
