larryn
Jun 07, 2014Explorer
rear end sag
I have an 09 1500 6l max tow. I will be able to tow my new 5er and stay within the specs, but it will be close.I am worried about rear end sag, what is a good way to relevel my truck if required.Airb...
goducks10 wrote:Cummins12V98 wrote:
Why do people think they meed to maintain unloaded ride weight when towing??????????
I see this all the time, rear of truck is high with proper bed rail clearance but the 5er is way nose high. Its because these people for some reason "think" they need to tow at solo ride height.
If your truck sits "level" with the RV attached you are probably good to go. If it sits lower in the rear than the front you probably are overloaded and bags are just a band-aid.
So true. Trucks come with the rear 2-3" higher than the front for that reason alone. If it drops 2" it's still higher than the front.
Mootpoint wrote:
Rear end sagging with OEM equipment. Not enough TV in my estimation. If I have to add aftermarket items to "improve" the ride I would really start considering the safety aspect of the rest of the OEM equipment. Should I beef up the brakes? Larger capacity coolers needed? Tires and rims? Axles? Engine and transmission? Structural strength of the frame? I could go on.
JMHO
