larrynExplorerJun 07, 2014rear end sagI have an 09 1500 6l max tow. I will be able to tow my new 5er and stay within the specs, but it will be close.I am worried about rear end sag, what is a good way to relevel my truck if required.Airb...Show More
Cummins12V98Explorer IIIJul 08, 2014My point is if your truck can't handle the load without aids as in it's not a stable safe ride. You need a bigger TV.I have bags as I have said not because it helps with the safe operation but because it helps with ride big difference.Buu a truck with more capacity than you need because you WILL end up with a bigger RV!
Related ContentTow Vehicle Rear End SagClass C rear end sag and banging!Rear end ratiosRear of camper saggingImproving rear sag
