therink
Oct 23, 2013Explorer
Sledge Hammer wrote:therink wrote:
I had same issue with my 2013 Keystone Fifth wheel. Then rear most floor vent did not get as much flow as the others. First thing I did was remove all floor registers and placed a small mirror into the duct at each register using a flashlight to see down entire duct to confirm there were no obstructions (all was clear). Using cardboard and foil tape I then fabricated and barrier in the duct at the rear floor register opening so air would no longer flow in the duct beyond the rear register. This appeared to add about 25% flow improvement to the rear without having to restrict flow to the front registers. While I was at it, I did the same at the front register. In my opinion, the extended duct ends served no purpose in my rig but to trap and restrict air flow.
Steve.
I wonder if those extended duct ends you speak of are what heats the underbelly and keeps the water tanks from freezing.
Not in my rig, but should be verified as needed.
About Fifth Wheel Group
