rhagfo
Apr 24, 2016Explorer III
alboy wrote:
Dont eliminate a plan because the fridge is blocked.In most cases in less than 10 sec your in there.Your on holidays and not in a race.
So true! Our frig is blocked with the slide, problem solved wit small ice chest in the TV.
To the OP's question, I will that you just need to watch your pin weight! We have a RK and to help always travel with the FW tank full as it is forward of the axles. Low pin weight and nose high will be more of an issue then RK.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
