garyp4951
Feb 22, 2017Explorer III
Just using recycled milling would be a mistake since it will never harden up. A new hot asphalt mix with just a percentage of milling added is fine, and almost all new roads have a small percentage of recycled milling added to the mix.
If you use the hot asphalt paving, the base must be compacted dirt, or gravel.
Crushed concrete makes a good gravel surface, and is comparable to a limestone driveway, but a little less in cost. All gravel surfaces need maintenance time to time, and do not need as much base prep as the asphalt.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
