PmsPks's avatar
PmsPks
Red Propane Regulator - Why?
OK folks. I need someone to enlighten me on why the red high pressure propane regulator on my "curb-side" tank is required. I have a 3 - 20# bottle system, 2 bottles on road side and one on curb side. The two on road side, one goes into one side of the auto changeover regulator, the other into the other side of the auto changeover via a tee, which has the line from the curb side bottle. It seems to me that the red regulator is really not needed since that line goes into the tee with a non-regulated bottle. Am I missing something here? Reason for asking is the red regulator leaks badly around the edge crimp when I turn on the non-regulated bottle on the other side. I have a new one on order by the way.
  • That would make sense if the line was running somewhere other than the same compartment as the other two bottles.
  • These are known to leak. Not sure why it is needed but I did replace one on my last trailer but I believe the replacement was higher flow. Luckily cheap (probably why they fail - 3rd world part).
