Atom_Ant
Jul 21, 2013Explorer
I just replaced my Reese 16K with the 20K Select using the original rails. I don't know about Huskey. The 20K is narrower, so it uses different holes in the rail than our 16K and requires the rail to be bolted in the middle as well as the ends (per the Reese install manual). I had to add those bolts in each rail.
I like the wrap around lock on the 20K, and the large platform. It does require that you hitch up a little lower than what it was with our older hitch, and as a result I tend to break the aftermarket nylon greeseless disk every once in a while. It is a nice sturdy hitch.
About Fifth Wheel Group
